02-19-2024 01:58 PM
I was trying to transfer my number to public mobile, but I don't know why it is not working. I replied the 'confirmation message' from old provider and confirmed with them that I am not with them now.
The mobile app tried to activate the eSIM yesterday, but it told me 'failed to activate' after 1-2 hours. Can I re-trigger the activation process? I believe the eSIM is still in the phone (Is there a way to confirm it?)
Thank you.
02-19-2024 02:13 PM
I played with iPhone setting a bit, the Primary/Data line label is quite misleading. I enabled the Data line and it automatically re-labeled as Primary, and everything is working now. Thank you guys!
02-19-2024 02:01 PM
click the little envelop icon top right side of the page...I sent the number for port reactivate.
02-19-2024 02:01 PM
@LXL it is an eSIM problem instead of port
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
