06-29-2023 03:15 PM
with my LG x power, it says not compatible with the app
06-29-2023 06:34 PM
@nanalynn wrote:with my LG x power, it says not compatible with the app
For the Android version of the app, you'll need a phone that has at least Android 8.
06-29-2023 03:29 PM
thought I was asking a CS agent for help, they helped my husband with the same type of phone
06-29-2023 03:25 PM - edited 06-29-2023 03:27 PM
The LG X Power is operating on the old OS 6.0.1 (Marshmallow) and probably won’t support the PM app or any new apps. The latest Android update is OS 13.
I would suggest you use a friend with a new phone to activate your SIM. Once the SIM is activated, your friend can delete the app and you can login on your computer to manage your account.
Maybe try contacting a CS_Agent to help you activate your SIM by private messaging on your computer.
06-29-2023 03:19 PM
Is that a Google region error?
