11-30-2020 05:10 PM - edited 01-05-2022 05:35 PM
when i try to get in my account its say my account is deactivate
can someone help !
02-08-2021 09:29 AM
02-08-2021 08:49 AM
02-02-2021 11:54 AM
can i juste activate my number and go with a other company?
12-01-2020 01:54 AM
@johnson1 wrote:Its been like a month that its not working me I thought that it was going to leave but as they did not I decided to contact you and it still does not work
Contact a moderator and ask for assistance to get into your account.
Here’s how to contact the Moderator Team (Public Mobile representative) for assistance:
12-01-2020 01:41 AM
11-30-2020 10:58 PM
@johnson1 wrote:i still have the service bet my LTE its not refreshing and when i decide to go and check in my account deactivate idk why
@johnson1 try this ..
If your device has a removable battery, remove the battery and put it back in before turning your phone on again.
11-30-2020 10:49 PM
11-30-2020 05:48 PM - last edited on 02-03-2021 06:28 PM by Ioana_R
@johnson1 wrote:when i try to get in my account its say my account is deactivate
can someone help !
Hi @johnson1 it could mean that you had not paid your services for more than 90 days. If this is true, then your phone number is gone, and you will need a new sim card if you want to activate a new account.
If this is not the case, do you still have service? If yes, that's good. It might just be a glitch so contact a moderator as suggested above.
If you don't have service, then you might be victim of port fraud.
>> check out if your phone number had been ported out by using reverse phone search
If any case, Please call our Porting Team ****
they might be able to help you.
Best wishes
11-30-2020 05:26 PM
can someone help !
What does it say when you dial 611 from your phone?
11-30-2020 05:16 PM - edited 11-30-2020 07:47 PM
11-30-2020 05:16 PM
I think the Chat Bot is your friend now
Alternatively, you can send a private message to the Moderators by :
