is a LG G7 one compatible?
MamaLu
My mother has a LG G7 one and we can find on the list.  Does anyone know if its compatible?
chukdefatey
@MamaLu
All Canadian Phones sold since 2016 are compatible with every provider in this country as long as the phone is unlocked.
FYI: Every Phone sold in this country since 2017 is fully unlocked and compatible with every provider in Canada
yes it will.
Best to get the American version.  Other version will work but won't work as well.
also, you might need to do a network reset or factory reset when you first setup to use on PM
Triguy
Yes, make sure it is the global or North American variant.
@MamaLu
Yes ia will working with public mobile,
visit Here link to you can see full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
