04-15-2022 07:06 PM
04-15-2022 07:41 PM
That would have been quite the coincidence? I am assuming the 611 method worked then and it wasn't a 24 hour hold then @stefania1212121
04-15-2022 07:25 PM
It's ridiculous but yes some stores have a delay. Maybe just contact the support people. Click on get help up top and then use the simon chatbot to find the way to send a message or a ticket.
You could try waiting an hour to try again. But only attempt twice again. If you've been trying a bunch of times then it may be a problem now anyway.
04-15-2022 07:20 PM
@stefania1212121 wrote:i got about 2 hours ago from a gza station
Which gas station? usually those from Shell can be use immediately
04-15-2022 07:18 PM
they say can proces this request to ask online why?
04-15-2022 07:17 PM
i did enter the 12 digit do we have to wait 24 h to use the code ?
04-15-2022 07:15 PM
04-15-2022 07:11 PM
Are you also Saadileila? Similar spelling of "vocher".
Can you try dialing 611 to enter the voucher? Does the voucher have more than one 12 digit set of numbers?
Some stores have a delay for when the voucher is usable.
04-15-2022 07:09 PM
@stefania1212121 depends where you got your voucher from. Vouchers from some store have a 24 hours wait time.
So, did you try to load both via *611 and via My Account ? Has it been over 24 hours since you got them?
