12-10-2021 10:12 AM - edited 01-04-2022 04:53 AM
I got a bonus of 500 mins int'l long-distance call, how to dial a local phone No. in Shanghai, China?
how to send a text to Shanghai, China? since intl texts incoming and outcoming are all free.
what is the dial/text format?
do I have to input 01186 +local phone No. ? or + 86 xxxxxx, add + sign in the beginning?
12-10-2021 12:10 PM
SMS or call China from Canada, dial: 011 - 86 - Area Code
Land Phone Number 011 - 86 - 11 Digit Mobile Number.
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet Wi-Fi is on is not going through the Picture or a video messaging,
you have to do this to going through you will need to turn your data on to send a Picture or a video messaging in world-wide,
make sure your Data is on.
12-10-2021 10:27 AM - edited 12-10-2021 03:32 PM
@chch518 wrote:I got a bonus of 500 mins int'l long-distance call, how to dial a local phone No. in Shanghai, China?
Either format should work although most people will probably use +86 for both calls and text messages as it's shorter.
12-10-2021 10:27 AM
Yes, 011 86 + phone number.
12-10-2021 10:16 AM - edited 12-10-2021 10:17 AM
@chch518 : Yes. It's the same idea for all dialing regions. You need to "get out" of your dialing region, select the country, in our case in Canada/US - drop leading zeroes anywhere including area codes, then dial the number.
So for here, try 011 first and if trouble try + as the method to get out.
