how do i cancel my account
Daver667
How do i cancel my account, please help
Daver667
thanks for your assistance, however, i do not know how to get 4 pin number
HI @Daver667
you can call *611 and use your 4 digits code to disable Autopay
or you can also login My Account, Payment, Manage Subscription and disable "Subscripted" to disable Autopay
Once Autopay is disable, PM cannot take money again.  Your account will be suspended at the end of your current cycle and will be closed 90 days after that
@Daver667
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead.  Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
@Daver667
Port your number out or
Turn off auto subscribe in your account payment >manage subscription >manage payment method like this . But if you cannot log in you can use this direct link to support to remove  credit card on file right away
Turn  auto pay  OFF/ON  3 easy clicks
Or if you know the 4 digit PIN number
*611
link for support here
send a  private message   To CS_Agents click
JRod
@Daver667
To close the account go to subscription and add-on’s, manage subscription, and then turn off auto pay. This can also be done with 611 if you know your account pin.
Once a payment isn’t made the account will automatically close in 90 Days.
You can also message support to remove the credit card that is attached to the account.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
If you wish to keep the number and port your number elsewhere that will also close your account automatically once the port is completed.
