help needed on the $15 plan
vanierlib
About the $15 plan with 250mb data ----what will happen after the 250mb data get used up?  will the data just gets cut off for the month? or people can still use data at a much slow speed (slow unlimited data)? Thanks
Nezgar
To add, when data is used up on the $15 plan, you can still send/receive MMS/picture messaging, and make/receive calls.
Chalupa_Batman
Just to add....  yes it will just stop working UNLESS the following 2 options have been met.
1. You purchase a data add on.
2. You happen to have Christmas data gift that was given last Christmas and haven't used.
WiFi is your friend!!!
DennyCrane
Your data will be cut off. No throttled unlimited data on that plan.
@vanierlib
PM is prepaid provider, you have to pay before using any service.  In this case, once the 250MB are used up, the data will stop working until a new cycle starts.  Of course, you can also buy data add-on so, you can continue using the data
