03-06-2023 04:05 PM
03-06-2023 04:08 PM
@bx701 Only PM support can update the email used for My Account login
Please open ticket with PM Support
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
03-06-2023 04:08 PM
HI @bx701
You will need to ask PM agent to help with the email change request
Please submit a ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
and a reminder, it is best to make sure the email address used in Community here is the same as the new email address you want to change to , so PM can match up the Community rewards
