double charged
martin345
I was charged twice for roaming
9 REPLIES 9
martin345
I have left a reply with the CS agent.
From July? Are you seeing the charges in your payment history? Or only on your credit card? If payment history, maybe you could provide an image of the transactions of that time.
@martin345 wrote:
It was purchased in July, 2022. I have 2 charges for roaming on the same day, same amount. I have not heard from public mobile other than the community.
@martin345   did you open a ticket with PM support? did you check your Community inbox here https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage   ?
if you opened ticket , and  checked Community inbox and no reply, open ticket with them again.
martin345
@martin345 @If you are owed a credit then at least you have it towards your next bill
@martin345
You can have it resolved by a CS_Agent for a refund but it may take up to 30 days.
Meow
When did you purchase US add-on (roaming)?
Did you accidentally pay twice?
What your account transactions show?
Do you see charge on your credit card? Maybe one is 'pending'?
hi @martin345 you can open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
dust2dust
Hmm. Are you the first person here to report a problem with roaming? 🙂 Did you click twice on the purchase button? Do you see the two charges in the payment history? Or do you see two "transactions" on your credit card? One might stay as pending and then drop off.
