data
Tates_123
I have gone over on my data plan three times in the past few months. I've had the same plan for a few years now and I have no idea what I'm doing differently. I clicked on an article through the Chatbot but it didn't tell me much.  Can someone please tell me how to figure this out??
@Tates_123  PM generally keeps track of the data usage well and correct
So, it is up to you to manage your data usage
Are you on Android? if so, check the data usage tracker on your phone.  Change the Start billing cycle on date to match your current PM cycle date, and you can tell how much data used and which app used most data
But if you are on iPhone, there is no way to look back on your usage, you can only Reset Statistics today and start tracking from today to see which app used all the data
To Reset data: go to Settings > Cellular or Settings > Mobile Data, and tap Reset Statistics
@Tates_123
in your phone settings, disable data to apps that you don't use on a regular basis. Also, disable Wifi Assist.
added...after the dreaded covid, we're all out and about again. Now using more data than when we were confined to barracks using home wifi.
@Tates_123 - are you receiving text messages warning you of using up your data?
Are you also looking on your My Account to confirm your data is in fact, being used up? Note, you can also call 611 to check your data balance (this includes any plan or data addon balances you have on your account).
I ask these questions to ensure you are using up your data, and confirm your device is not set to turn off when it reaches a certain level of data usage. Or have a data limiter enabled.
If you are really using up your plan data, check out some suggestions on helping with usage: https://www.publicmobile.ca/en/ns/get-help/articles/manage-your-data-usage
Tates_123
Thanks so much. I'll check all that out.
Chalupa_Batman
Depending on what phone you have... Android or iPhone you can close a bunch of apps that you don't frequently use. Also, turn off auto update as that can chew up a lot of data updating programs. If you haven't yet, download the PM app to check daily to see if data is still being used. You can also download a battery saver app which will show you which apps are using the most power which kind of indicates what apps are still running that might be using data. Hope this helps.
Here's something for Android - Check Internet Data Usage
Here's something for iPhone - My Data Manager VPN Security
Both of these are free and hopefully helps you figure out what's consuming so much data. OH, also turn on your WiFi as much as possible.
