07-12-2019 11:37 AM - edited 01-05-2022 05:51 AM
difficulty setting up an account to access my account number to transfer to another provider
07-12-2019 02:27 PM
I purchase it from Walmart
07-12-2019 02:20 PM
At Public mobile but when I try to enter my number it said the number not valid
07-12-2019 01:31 PM
@farrellm1 wrote:I want the 6-digit code via email instead of phone...how do i do that?
@popping wrote:
@farrellm1 wrote:I was not aware of a self serve account until now
Use this link to create your self-serve account. It will send you a 6 digits code to create your self-serve account.
https://selfserve.publicmobile.ca/self-registration/
That's not an option. It's only delivered by SMS. Where is your phone number now? At Public Mobile, or somewhere else?
07-12-2019 12:00 PM
not possible. the 6 digit code is to ensure the number you are creatinng the account for is your own.
@farrellm1did you join PM at a store or did it yourself online?
07-12-2019 11:57 AM
07-12-2019 11:56 AM
07-12-2019 11:44 AM
Are you bringing a phone number here, or sending it somewhere else?
07-12-2019 11:43 AM
Ah.. go to activate.publicmobile.ca
You will need to register, activate with a code sent to you by SMS
07-12-2019 11:43 AM
I did all off the above suggestions but to no avail
07-12-2019 11:41 AM
07-12-2019 11:41 AM - edited 07-12-2019 11:42 AM
@farrellm1 hi did you set up a self serve account alot of people don't and then they need it later
07-12-2019 11:40 AM
indicated my phone number is invalid or I have set up an account already...
07-12-2019 11:39 AM
@farrellm1 wrote:difficulty setting up an account to access my account number to transfer to another provider
@farrellm1 You want to transfer your public mobile phone number to another provider? Do you not have a self serve? Is the line active? Who set it up? Did you forget your password? Can you login here? https://selfserve.publicmobile.ca/ if not, try the password reset, if you don't have an account but have a number try to set one up here https://selfserve.publicmobile.ca/self-registration/
07-12-2019 11:39 AM
What's the issue you're having? Failure to log in, forget password? Do you have a self-service account?
