09-23-2021 06:16 PM - edited 01-06-2022 03:37 AM
Hey I am looking into buying a : Blackview BV4900 Téléphone portable débloqué 4 G Double SIM Android 10 3 Go + 32 Go Étanche IP68 Anti-chute Écran HD + Batterie 5580 mAh Vert.
Can someone tell me if it is compatible? It says yes on amazon but not on the list on Public mobile website
09-23-2021 07:46 PM
What is your upper budget for a rugged phone? What do you do that requires a rugged phone? Given the price and the unknown quality of the device and the manufacturer itself I would be a little leery of purchasing it. Given the possible cost of shipping it back to Hong Kong for any warranty issues perhaps we can suggest a more reputable rugged phone that can fit your upper budget. Sorry but I see disappointment in your future....of course you have the Amazon return policy just in case.
09-23-2021 06:29 PM
@Hannah65 : The phone will work fine. May be a little light on LTE.
09-23-2021 06:21 PM - edited 09-23-2021 06:32 PM
Yes both models will working with public mobile,
Blackview BV4900 - Specifications (devicespecifications.com)
and
Public Mobile uses the following frequency bands:
Good Luck
