06-06-2023 05:42 PM
chatbot won't process my payment. It asks me the amount to process when I enter an amount it says the amount does not look right...hoe can I process a payment. BTW, I do not like this new process...
No problem, I can help you make a payment
We have found a credit card registered on your account.
The payment amount must be between $1.00 and $300.00.
I’m sorry, I didn’t understand that question
You can try rephrasing your question and as you begin to type it or even just the keywords, I will provide suggestions for you to choose from.
06-06-2023 06:13 PM
thanks dust2dust...just noticed that you suggested to use 35..sorry I missed that.
06-06-2023 06:13 PM
@JamesA991 Thank you for reporting back to us 🙂
06-06-2023 06:12 PM
yes, I was also able to download an invoice for the transaction in the Payment History page.
06-06-2023 06:10 PM
yea, I used 35.00 with out the dollar sign. you figure an AI chatbot would be able to figure out a $ used to make a money transaction...where is the AI in that 🙂 also, the chatbot could just put it in the chat that it does not understand the language of money '$' so dont use it 🙂 thanks for helping out Handy1 !
06-06-2023 06:04 PM
@Handy1- lol I didn't know the chatbot was able to take money. I've looked a couple times since reading some posts about it thinking, really? I couldn't seem to easily find it.
@JamesA991- No there's no receipt from 611. Perfectly sound reasoning of yours. Often this place makes no sense though. Are you not able to log in to the account? You can use the website or the app. Preferably a non-mobile browser. Yes, more non-sense. A mobile company that has trouble with their mobile site. I'm also not sure the chatbot method would give a receipt either.
06-06-2023 06:02 PM
@JamesA991 Maybe try just putting in the 35 like that . Also would that cover the cost +tax ? And. I can’t confirm about invoice or not I suspect not
06-06-2023 05:54 PM
my plan cost is 35$. I used the format of the amount that chatbot used..."The payment amount must be between $1.00 and $300.00" ...hence why I used $35.00
06-06-2023 05:54 PM - edited 06-06-2023 05:54 PM
@JamesA991 That maybe a problem , but something @dust2dust would know
06-06-2023 05:52 PM
thanks for the reply. would I get an invoice sent to me if I use 611? I liked processing my payment online because I could download the invoice with official branding which I than sent into work for expense reimbursement.
06-06-2023 05:48 PM
What is your plan cost not taking into account any balance or rewards due? It might be that it wants the full plan cost. Would just 35 work. Not the $. Not the word dollar. Or 35.00 .
06-06-2023 05:46 PM
@JamesA991 You can 611 to make payment if your know the PIN number on account, or if you have vouchers no PIN needed
