06-24-2022 07:33 AM
Whenever I'm out somewhere I cannot use the data. I have 2.5 GB but it wont work
06-24-2022 01:01 PM
@Helen1975 What make and model is your phone?
Calls are ok and just not data?
Try to put your sim card in a test phone and check if you can find one
06-24-2022 12:59 PM
1. Turn your data turned on.
2. There may be some apps that you are trying to use that are switched OFF from using data.
06-24-2022 12:48 PM
@Helen1975 - also ensure you have data left on your plan within this current cycle.
If you do not see your data line listed in this area under your overview of your self serve account, that normally means you used it all up for this cycle.
So, if that is the case, you need to wait to replenish your plan data on next renewal, purchase a data addon, or renew your plan early (no prorating of already paid porting though).
06-24-2022 07:41 AM
@Helen1975 hi has it ever worked since you joined ? what type of phone is it? try a network reset
06-24-2022 07:37 AM - edited 07-07-2023 07:17 AM
do you ever able to use Mobile Data since joining PM?
First make sure Mobile Data is enabled
Also, make sure you didn't have any Data usage limit setup on the phone
Then next , check your APN settings. Issue like this is usually a problem with APN settings mismatch
For Android, check: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
For iOS, make sure Carrier Profile is up-to-date
First, sure your device is connected to a Wi-Fi
Tap Settings > General > About. If an update is available, you'll see an option to update your carrier settings.
if it still not working, let us know. Or post screenshots of your current APN settings
