cant turn on data on Moto 4g
cmd73
Hi
Joined PM about a week ago, no problems at all.
Phone calls no problem, texting no problem- just cant get data.
have gone to the website suggested by other members and configured the phone APS settings correctly, turned phone off and turned back on, turned on data on phone....but nothing.
Any ideas?
Lar
Open settings, tap data usage, tap data switch on.  Bingo you should have data
Cheers
cmd73
Thanks for the replies guys!! Really appreciate it.
- the phone info shows correct IMEI and phone number, PM as current network; is there any particular line of that screen that I should be looking at?
There's a lot of info on it....dont know how to do a screen shot...sorry 😞
geopublic
@cmd73 wrote:
Hi
Any ideas?
Dial *#*#4636#*#* on your phone. Select Phone information Under Data service what does it show?
Dunkman
@cmd73
Other ideas
network reset
potentially factory reset of phone (make sure to backup information)
May screen shot your APN settings for the community to have a look.  make sure there is any error...
