05-11-2022 12:21 PM
i removed my credit card info yesterday and i just got the usual sms notification that the payment went through(?)
05-11-2022 03:20 PM
At the bottom left corner of your overview page will tell you if you are signed up for dynamic autopay.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-11-2022 01:15 PM
i've had this account since feb, 2022. i don't think i had any extra funds. thank you for the info 🙂
05-11-2022 01:14 PM - edited 05-11-2022 01:18 PM
HI @pc11
You cannot check Autopay because your credit card is already removed
for PM still charged you, it could be that you removed the credit card too late last night and the renewal process already started
Proper way is to open ticket with PM Support
Easier way, but as I said earlier only if you decide never to come back, is to request credit card for a charge back
If you decide to open ticket with PM and argue and ask them for a refund, you can open ticket
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
05-11-2022 01:13 PM
status is showing as active.
i don't see my credit card info on there anymore and i have no idea how to check on autopay status
05-11-2022 01:04 PM
How long have you been a customer? Did you have any available funds in your account balance?
05-11-2022 12:34 PM - edited 05-11-2022 01:05 PM
HI @pc11 can you login to My Account and confirm if you see your account status showing Active?
Also, please confirm if you have any credit card there and if Autopay is disabled.
Depends on the time you removed your credit card, you might still got charged
If you decided to leave and not coming back for sure, you can call your credit card and ask for a chargeback/cancel the transaction. Your credit card will do that and your PM account will got suspended immediately after the chargeback is done
05-11-2022 12:27 PM - edited 05-11-2022 12:27 PM
When was your renewal date?
Usually processing occur in the early morning. If you did not remove your CC the day before most likely they still had your card on file and charged you.
If you are leaving PM you can go and dispute charge with your bank.
You should remove autopay first...
