08-14-2022 12:48 PM
08-14-2022 01:45 PM
tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,
08-14-2022 01:07 PM
HI @elsie93 you can reset PIN after you got back into My Account.
to reset My Account password, first try using the Password Reset option there. You can choose to have the security code to send to your phone or your email. But you still need to know the exact email address you used to login
If you cannot reset password yourself, please open ticket with PM CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
08-14-2022 01:02 PM
If you cannot log in to reset your PIN, try using different browser or incognito/private mode. Use computer not phone to do that.
If everything fails, contact agent for assistance.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner. It will show Number of unread emails.
