added more data. but it won't work
fingerlessjoe
Hi I added $30 more of data to my phone. But it hasn't been applied. My phone wont connect to Internet please help asap . Thank you
sleepycar
Hi Shazia,
I am having the same problem. Restarted my phone multiple times but no still no good.
Thanks.
fingerlessjoe
Thanks Shazia, I think you fixed it!
fingerlessjoe
No, you misunderstood. Thanks anyway, somebody fixed it.
Pier
Hello!
What do need help with exactly If you accidentally add up the data on your account, i don't think there is something that can be done for you. If the problem is because your phone can't use internet, you won't probably have no refund. Try to send a private message to Shazia_K or Mary_M, hopefully one of them will help you.
Yours,
Shazia_K
Retraité / Retired
Retraité / Retired
Hey @fingerlessjoe
I'm sorry about that!
Can you reboot your phone? I have added the data add-on for you.
Thanks,
Shazia
