12-27-2021 03:17 PM - edited 01-04-2022 04:46 AM
Hi, my (2GBBONUS) promo is not activated for December , don't know what to do?
12-28-2021 03:41 AM - edited 12-28-2021 03:41 AM
@luis2564 wrote:Hi, my (2GBBONUS) promo is not activated for December , don't know what to do?
Does your plan cost at least $35? That promo code of 2GBBONUS only applies to plans of $35 and above. If you signed up for a plan that costs less than $35/month, then this promo code wouldn't have been applied during Activation. As many have mentioned, you can check the "My Promotions" section in "My Account" to verify.
If you feel you are entitled to this promotion and it's not applied, then you can contact the Customer Service of Public Mobile by sending a private message to "CS_Agent". Just click on the icon marked "Message" here to compose the private message.
Hope this helps.
12-28-2021 03:14 AM - edited 12-28-2021 03:16 AM
Did you purchase a $35 or higher plan? It normally takes up to 3 days to be in your account.
If you did then contact a CS_Agent to look into it for you by clicking on the SIMon chat button and type in Create a Ticket then follow the prompts.
Since you activated in December, you qualify for the More is Merrier promo where you get a one time free bonus 2gb of data and 500 minutes of international calling.
12-27-2021 03:26 PM
For 2GB of monthly bonus data for Free* when you activations on $35, $40, $50,$60, $70 rate plans, for that Promo code for 2GB , 2GBBONUS , that monthly bonus for 2GB no expires but you have to keep your plan and if you changed your plan you will lost the promo 2GB, just to you know.
note: it may take up to 2 to 5 business days for bonus data to be applied.
if you miss it or not apply yet you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck..
12-27-2021 03:26 PM - edited 12-27-2021 03:26 PM
HI @luis2564 did you activate plan $35 and above? If so and if you did put in the code and if you have activated for over 72 hours, then you can open a ticket with PM and they will confirm and add it back for you.
To open a ticket with PM support, click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
12-27-2021 03:19 PM - edited 12-27-2021 03:24 PM
If you just activated on a $35 or higher plan, and used the promotion code in the Activation Portal, you will see the bonus in your "My Promotions" section of your self-serve within 48 hours.
Please review announcement from Public Mobile in the attached:
