05-10-2021 09:54 AM - edited 01-06-2022 02:01 AM
Just got activated with public mobile. Phone and text works great
Data will not work on this phone? Is it a phone problem or some issue with Public
Data works fine in other phones I've tested the sim card in?
05-10-2021 10:22 AM
It's working thank you so much!!
05-10-2021 10:17 AM
Just put in these APN settings
Made sure data was on
Chose automatic registration for networks
05-10-2021 10:05 AM
Just checked the specs on your phone and it is compatible with PM.
https://www.gsmarena.com/zte_grand_x2-7656.php
Might need to adjust your APN settings.
Here is one version of APN:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
05-10-2021 10:01 AM
I can change it: what is the correct settings?
05-10-2021 09:58 AM
z850
05-10-2021 09:57 AM
R u able to change your apn on ur phone? If it doesn't give u the option to then u need to get a Freedom Mobile Sim card. When u put that in ur phone then u can change ur apn. I know it sounds strange but it does work. I had to do it to mine.
05-10-2021 09:57 AM
Since data works in other phones, it is likely a setup issue with your ZTE phone. Not a public mobile service problem. Which model of ZTE phone?
Maybe try rebooting phone. Network reset. You may need to adjust APN settings. You can screenshot your APN settings and we can offer some suggestions.
