09-14-2023 06:42 PM
Hi,
I meant to upgrade my plan from the $25 to $34 (prepay 3 months) but clicked the $39 one
i actually selected both within seconds. Is there a way to get the $39 back or will it be added as a credit to the next payment ?
09-14-2023 08:23 PM
Jeez. My bad. At my kids soccer and wasn’t paying attention. No lie, I can’t find that however I will rectify this error. Sorry
09-14-2023 07:03 PM
09-14-2023 06:52 PM
You are amazing Handy! Thank you !
09-14-2023 06:49 PM
@DAJ , did you select the plan change to take effect immediately? If the plan change is set for next renewal, you can cancel and redo the plan change. Otherwise reach out to support as suggested.
09-14-2023 06:44 PM
@DAJ Use this direct link to support explain what happened honest mistake . And hopefully they can reverse it for you
send a private message To CS_Agents click
VVVVV Link below VVVVV
