05-02-2015 01:46 PM - edited 01-04-2022 01:26 PM
I amy trying to use WIFI and it asks for my password,which one do i need,the password i use with phone account or my email account,cant seem to login
05-05-2015 05:45 PM
All is ok now,WIFI is working.
05-05-2015 05:38 PM
UPDATE...
I got the WIFI working,it finally kicked in ,i did log in to Tims agreements and its ok now,,,
Thank you to all who helped me.
05-05-2015 04:49 PM
UPDATE:
I just came back from Timmys and i asked the manager about the WIFI,she says its ready to go.no need to sign agreements and stuff.It shows im connected to the WIF as soon as i open the phone.I can login now with my googlr account and browser opens but i get this messgae now
''securelogin.arubanetworks.com''
cant seem to get pass this.
05-05-2015 04:46 PM
Tim Hortons WiFi is FREE. No need to have an account with Public Mobile to use their WiFi.
05-05-2015 04:28 PM
05-05-2015 04:01 PM
Thanks for replying.Seems like i need to log on first with my email account but keeps trying to syc and no go.I checked my IMEI number and thats ok.I try to go too google and no way.
05-05-2015 03:52 PM
You have to open your browser and accepts Tim Hortons conditions.
After that, you will be able to surf.
05-05-2015 03:45 PM
Anyone having problems with WIFI.At the coffee shop it shows i am WIFI connected but i cant seem to log into my accounts.
05-03-2015 03:09 AM
05-02-2015 11:38 PM
Personally, I use my Data, or use Public WiFi in areas that I know, so that I avoid the hassles of unreliable WiFi services.
Plus, some WiFi hotspots have filters, so that your ability to surf certain websites maybe Hampered
05-02-2015 11:36 PM
If you don't register, you can still connect, but you'd have to, every time you connect, similar to how McDonalds WiFi is set up, or how certain Malls public WiFi is set up. There are some WiFi that require a CC because its NOT free, so you must always determine which is free, and what's not
05-02-2015 11:12 PM
than it means that you already registered
so give your email but use a password (not the one for your email)
05-02-2015 10:36 PM
Hello. I know what you are talking about.
Tims has the free WiFi and the one where you register your handset #, email so that you can sync w/o having to agree to Tims ToU everytime
05-02-2015 10:28 PM
05-02-2015 10:20 PM
05-02-2015 02:11 PM
