Why am I getting a false data warning message?
DaveT
I received a text saying I am 75% through my data which is confusing how much I really have left. This table is what my self serve says I have used:
 NameData Limit* (MB)Data Used** (MB)Remaining Data (MB)Status
1 GB of data at 3G Speed1024709.729314.272Active
1GB Promo1024542.787481.213Active
4GB one-time data bonus40963104.780991.220Active
So according to this it looks like I still have almost 1800MB remaining. Does that seem right? If this is the case, then I should not have anything to worry about! However last month my data slowed down or basically stopped working in my last day or two so something seems funny here. Also I set my phone to measure data based on my billing cycle and it says I have only used 651MB - I don't get how they could measure that I used so much more than what my phone measures! Doesn't seem right.
7 REPLIES 7
DaveT
Thanks!
@Anonymous   ok, will keep that in mind. thanks
 @hTideGnow : I disagree. Please don't report me for tagging and calling you out like some people like to do. 🙂
The warnings are on the gross available data.
@DaveT   the 75% data used is regarding your monthly data bucket, does not take into consideration of your promo bonus
However, yours monthly is still 30% left..
...and this text is not very accurate.  Not sure why, many people mentioned the error before but PM has not fixed the glitch still
BlueB
@DaveT
Oh, you've discovered another Public Mobile glitch!  We see this happen from time to time, so I wouldn't worry about it.
How much data do you get as part of your normal Plan every cycle?  It's possible that you've used ~75% of your "normal" data (ignoring Add-Ons/Bonuses) and that triggered the warning.
Regardless, if you've checked your Self Serve account and everything looks good, then just ignore the text... it happens!  🙂
 @DaveT : Your remaining data is 75% of your total data. When your plan data resets at renewal then it won't be 75% anymore.
Ignore the erroneous text message.  The Public Mobile systems, when it comes to your ability to use the service, go by the same infformationm that your Self Serve account shows.
