When i put my sim card into another phone all my data disappeare
Seawatersoul
The other phone i was using totally glitched...like so Glitched It's absolutely and totally unusable so I put my simcard into this moto z2 play and because that pm was saying I still have atleast 1GB  SO ANNOYING !!! you guys and gals ever experience this?  If you did what was the fix? Thank you for All you do
11 REPLIES 11
JK8
Log into self service and look under My Data & Add-Ons to confirm your amount of data you have left.
Seawatersoul
That is actually how are knew I had data left m'dear 😉
LurganIeUk
Makes sense.
Ok so you want to use your 1GB
What?
Fix what?
@Seawatersoul ...so what actually did you see before and see after.
It sounds like you seen 1GB after you made the switch??
S--S
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
How to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  HERE
click HERE
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
or if you like it to do factory reset settings to cleaning everything.
It is possible the new phone was using the Mobile Data to download OS update or Google Store download.  Or It is also possible you were setting up the phone and Google was downloading the backup/restore files off the cloud using Mobile Data.
If you was following phone setup when you use this "another" phone, it sounds to me that you didn't setup Wifi during the phone  setup process
@S--S, sorry just don't understand, how reboot or reseat SIM helps to get the 1GB data back?
og2
@Seawatersoul
Click on the APN settings link in @S--S  post.
That is the main fix to look at
