What's a voicemail number ?
dgoulais1114
@geopublic
Thanks for privoding such a detailed list.  I would suggest using city names instead of one of area code that city uses.  I believe that this might cause people to try using random area codes to see if the number works, or people beleiving that they can only use that voicemail retrieval number if their number is from the mentioned area code.
If we take the example of Toronto (only because that's what I'm familiar with), people might ask which number to call if they have a 437 area code number.
Have you had a chance to determime if some of these are retreival numbers, while some deposit numbers?
Sizzle
Could it be a number you had to set up you voice mail like a password so only you can get into your voicemail, for security purposes?
geopublic
@dgoulais1114
Here is the list to all Access numbers. Pick the one for your location or hold down the 1 ley on your dialer.
204 (oustide of Winnipeg) 204-588-4002
204 (Winnipeg) 204-588-4001 204-588-4002
226 (226-580-4001)
250 (778-581-4001 778-581-4002)
289 (289-680-4001)
306 (587-580-4002)
403 (587-580-4001 587-580-4002 587-580-4003)
416 (647-580-4001 647-580-4002)
418 (581-580-4001)
438 (438-580-4001)
450 (450-320-4001)
506 (506-588-4001)
514 (438-580-4001)
519 (226-580-4001)
581 (581-580-4001)
587 (587-588-4002)
604 (greater Vancouver area 778-580-4002)
604 (Outside greater Vancouver area 778-580-4003)
613 (613-581-4001)
647 (647-580-4001 647-580-4002)
705 (705-780-4001)
709 902-580-4001
778 (outside greater Vancouver area 778-580-4001)
778 (greater Vancouver area 778-580-4002)
780 (587-588-4001 587-588-4002)
807 (705-780-4001)
819 (819-588-4001)
902 (902-580-4001)
905 (289-680-4001)
Triguy
Here is info about how to setup your voicemail.
  1. Hold down the ‘1’ key on your phone keypad to dial your voicemail access number. Calling your own 10-digit phone number will also bring you to your voicemail.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
