What if I don't receive and activate my SIM card before the promotion expires?
Steph_Atlas
I signed up for the new customer $34/month Canada-US plan. The promotion expires March 4. What if I don't receive and activate my new SIM card by then? Will I still get the promotion?
 @Sleuth_4_Truth  don’t think there is a time limit but typically to hold  off for 2-3 monthes before activating the sim should be no issue at all I’ve never waiting longer then month to do so . But I can’t say it’s indefinitely years later either . Be nice to get some clarification on that just to know for kicks
hi @Sleuth_4_Truth they dont have a time limit as long as it is reasonable
 Within. a month would be fine.  If not receive sim  in 3 weeks, check with suppoet agent.  So, No worries
Sleuth_4_Truth
Do you happen to know what the time limit is in order to activate the SIM?
@Steph_Atlas  That’s okay if you already paid for the plan it’s locked in and the plan won’t start u til you activate the sim on the app.
