05-21-2022 03:42 AM
So I am traveling to another country right now, and my account will be deactivated on Aug 16, and what would happen if my sim is deactivated, will I be able to use the phone number, or should I keep top up every month.
08-22-2022 03:19 PM
05-21-2022 01:56 PM
If you are back by early August you will be fine, if not you could reactivate even the cheapest plan and that would buy you another 120 days essentially (30 day plan plus 90 days suspended period
05-21-2022 08:37 AM
If you allow your phone to go 90 days without pad service it will be cancelled and deactivated. You will lose your phone number and if you are on the $$ rewards program you will not be able to activate a new account with $$ rewards rather the less lucrative points system. Here are the options for your service.....
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels and Stay--Safe!
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-21-2022 04:26 AM
If your account expires on August 16, your account will be placed on Suspended. I would suggest you make a payment on August 11 to reactive your account which will leave 5 days incase there is an issue with reactivating your account.
Once your account expires, you will loss your phone number.
The other option is to change your plan to $15/month on AutoPay if you are paying a high priced plan. This will guaranteed to keep your number.
05-21-2022 03:56 AM
@TueTran1305 wrote:So I am traveling to another country right now, and my account will be deactivated on Aug 16, and what would happen if my sim is deactivated, will I be able to use the phone number, or should I keep top up every month.
When's the last time it renewed fully? You have 90 days from then or the account gets closed forever. If you pay and reactive the plan before August 16, you keep the number.
