What does it mean $10 credit for activation
Dumb1
Please advise what it means to have $10 for activation as new member.
BeachNBeer
@Dumb1
Il s'agit d'un crédit gratuit de 10 $ qui sera utilisé sur votre facture du mois suivant. Si vous connaissez quelqu'un sur Public Mobile comme un ami ou un membre de votre famille, vous pouvez lui demander son code de parrainage. Si vous ne le faites pas, vous pouvez demander ici et quelqu'un peut vous envoyer un message privé avec un code. Pendant que vous êtes sur la page d'activation créant votre compte, il y aura une section qui vous le demandera. Après l'activation, il sera crédité sur votre compte dans les 72 heures.
edit - at first ops question appeared in French but now it's in English. 🤷🏻‍♂️ sorry for the French lol. Wish PM would revert back to old forums.
@Dumb1
activation is Free,
when you Enter Friend Referral Code..you will receive a one-time credit $10..,,
they will applied within 72hr.
@Dumb1
If you enter a referral code during activation (both the referral code box and promocode box are on the 4th page of the activation portal) you will recieve a bonus $10 credit on your account within 72 hours of activation. The friend or family member whose referral code you entered will recieve a $1 reward per month that you maintain an active account with pm.
It's best if you need a referral code to simply private message any member you choose and ask them for their referral code. They will be happy to oblige. Unsolicited referral codes are against the community's terms of service and should be reported. By you reaching out it prevents your private message box from being inundated with referral codes and creating a headache for yourself.
okellyki
For using a referral code you can essentially get $10 of credit that can be applied against bills or upgrades!
helloiamtrang
When activating your sim, you enter a referral code received from a friend. You’ll receive a one-time credit $10. For the second renewal, the amount charged will be less than the actual balance. For examples, your plan is $15/month. It’ll be $5 in the second cycle.
