09-18-2022 06:00 PM
Hello my name is Meirwaise Omari and I would like to create an account. Please
09-18-2022 11:25 PM
You can purchase a voucher to load your account in the meantime once a CS_Agent has cleared this up for you.
You can purchase one from these location and dial 611 to enter the voucher number:
09-18-2022 08:20 PM - edited 09-18-2022 08:23 PM
The previous responder already said that more than 2 hours ealrier.
09-18-2022 06:15 PM
@Omari-Meir wrote:I tried every way and because it’s been ten years I don’t remember which I registered with. Please if you can check my account and let me know thank you. My phone number is 416-xxx-xxxx
Please do not post any personal details here on the public community.
You will need to reach out to the CS_Agent so they look up your account info.
Here’s when and how to contact our Customer Support Agents:
09-18-2022 06:14 PM
The time I got the service that time there was customer service I don’t think I had email address on file.
09-18-2022 06:12 PM - last edited on 09-18-2022 06:14 PM by NDesai
09-18-2022 06:10 PM
So... do you have self serving account or not? How it was set up 10 years ago with autopay?
If you have PM SIM and activated account/service go to Sign In, My account and create self-serving account.
09-18-2022 06:10 PM
@Omari-Meir If it's been that long, you should already have an account. Try logging in to your self-serve account using the email address you used during activation. If you do not know what email address it was, search for the Welcome email that Public Mobile sends when you activate. Once you know the email, try logging in or reset password.
09-18-2022 06:05 PM
I’ve been with public mobile for the last ten years and I had pre auto pay on file but because my credit card is expired now and automatically my plan doesn’t renew and I’m trying to open my account. So I can update my credit card on file.
09-18-2022 06:02 PM
@Omari-Meir Do you have a SIM card? If yes, you will need to activate it here: https://activate.publicmobile.ca/
If you are already an existing customers, login here using your email address you used during activation.
