05-26-2018 05:08 PM - edited 01-05-2022 04:49 AM
Hi There peeps,
I got my PM SIM activated at Walmart in Dieppe, NB today and now I need to port my PC Mobile number to it. When I try it using self-serve, I get an error saying it can't be done. I've checked with PC Mobile and they say there is no issue with my number or my account. Can someone help me please 🙂
06-20-2018 08:18 AM - edited 06-20-2018 08:20 AM
@gr8white wrote:I also signed up 2 lines at Walmart. I had no problem porting the 1st number but, the other kept having an error message; I kept trying and, a few hours later it worked for my 2nd line.
I referred a friend, got referal confirmation via text & bonus but, have $0 in account; I assume it will just take time to upload the actual credit considering I recieved confirmation for my successful referal.
Yes, it can take up to 72 hours to get the credit.
06-20-2018 08:00 AM
06-18-2018 01:54 PM
Is your phone unlocked? I called my previous provider while in the Walmart store, and it was done immediately. The rest of the activation was seamless!
05-26-2018 11:26 PM
I suspect this error likely has to do with the fact that PC Mobile postpaid service is essentially Telus. As said earlier, if you're getting an error message like this, you'll have to contact the moderators.
05-26-2018 05:23 PM
According to your issues, I recommend you send a private message to the moderator team and ask them to investigate. include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
How long until a moderator replies?:
How can I view my private messages between myself and a Community Moderator?
05-26-2018 05:17 PM
Also, for some reason my friend's referral didn't go through either. Can this be fixed?
05-26-2018 05:11 PM
This is the error I get:
