Voicemail Greeting issue
Marvintheone
Hello,
Every time I record a custom greeting and I activate the greeting, It still gives me the standard greeting.
Thank you in advance,
@Marvintheone   If it's malfunctioning you would need to contact customer service since we're all customers here in the community so can't do anything other than help troubleshoot.  Send a private message to the agents using this link
Marvintheone
of course I enabled it I’m a very tech savvy person and I would know how to do this. It’s malfunctioning thank you
hi @Marvintheone
this is what you missed and need to do now.
after you are in the Voicemail, click 3 for greetings, then 1 for Personal greeting and 1 to activate
@Marvintheone  Here’s some reading on how to set up voicemail greeting
https://www.publicmobile.ca/en/ns/get-help/articles/voicemail-faqs
dwh1
@Marvintheone wrote:
Hello,
Do you have an iPhone running iOS 17?  If you do, you’re probably getting the phone’s live voicemail greeting that can’t be changed. You could test this by disabling live voicemail under Settings/Phone.
hi @Marvintheone after you record customer greetings, you need to enable it , did you??
