01-06-2022 09:14 AM
everything is same as before . but we’ve been experiencing very poor network at home for last two months .
01-06-2022 03:55 PM
I’ve been using public mobile for a long years but suddenly from mid November phone network at my home became worse. PM tech support is looking into it as it’s a PM technical problem (either client priority or network loop hole due to some change at PM)
01-06-2022 03:33 PM
Do you have a well insulated home? Insulation in particular interferes with cellular network signal along with other construction materials. You could consider a cell signal booster.
01-06-2022 03:29 PM
@faruk wrote:Actually at my home, public mobile phone network is very poor, only one bar(20% network) available. Outside home, 2-3bars.
Outside home means right at your front yard? if that is the case, that is a true, your house was built with good material 🙂
Try changing to 3G only for a week and see if it works better, as I explained, it could be just temporary due to infrastructure upgrade.
My next question to you is what kind of phone you have?
01-06-2022 03:21 PM
01-06-2022 01:34 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
if you still not fix it you need to report to TELUS Service Status
maybe is there a issue with Towers in your area,
visit to Coverage Map Here .
or Here
and check it out is enough Towers in your area.
01-06-2022 10:39 AM - edited 01-06-2022 10:39 AM
did you try changing your network to 3G Only? It could help.
From what we heard, telcom are busy upgrading their infrastructure to 5G . If they are working in your area, it could have poor connection and 3G Only is a temporary work around. Test it out and see if it helps
Of course, you can open a ticket with PM to have them to check, to open ticket with PM:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
01-06-2022 10:27 AM
Problem is with phone network, only one bar shows on phone at my home. Sometimes can’t make call, can’t receive call. Two months ago everything was good. Tech support has to resolve this issue.
01-06-2022 10:26 AM
01-06-2022 09:29 AM
@faruk is the data /internet on your phone being slow due to the poor network or your phone voice quality affected?
did you try changing your phone network setting to 3G Only ?
01-06-2022 09:25 AM
Are you saying your signal bars on your phone are poor?
01-06-2022 09:21 AM
Some more information would be helpful.
Was your network fine prior to two months ago? What is happening? Poor talk quality? Data issues? unable to send/receive texts? Multiple phones/accounts having the same issue? Which model phone?
