Verification codes
trusted_source1
I'm not receiving verification codes for 2FA from foreign financial institutions (U.S. or UK). When there is an option to receive the code via telephone call then I get the call. But if the only option is to click on "Send Code" then I don't receive it and the transaction fails. Codes from Canadian banks come through fine. Text and SMS worldwide OK! Diagnosis? Remedy? Thanks.
10 REPLIES 10
trusted_source1
Thank you for the link to the blog post. I will see if that offers any potential solutions.
@trusted_source1 wrote:
That list of short codes seems to be about where I can send rather than from where and what I can receive. Is that right?
@trusted_source1
No, the list of short codes there is the approved list for both send and receive
 I don't know what it means that short codes only work locally. Does it vary by carrier?
@trusted_source1
banks uses short code (those 6 digits code instead of a regular phone number) to send 2FA code
those shortcodes are designed to work in that particular country and not send overseas.  In other work, your overseas bank's 2FA code won't send to Canada
Even banks uses regular phone number to send code, it might not work due to CASL (Canada’s Anti-Spam Legislation)
https://www.twilio.com/blog/2017/11/due-to-casl-canadian-carriers-might-be-locking-out-your-users.ht...
 what's the point of having a credit card at a foreign bank if you can't make purchases with it in Canada?.
You can still use it in Canada, you just either need to turn off 2FA or as I said in my above post, reach out to your bank and ask them what the alternative ways are to get the 2FA codes, authenticator app or email?
trusted_source1
trusted_source1
It has never worked but I thought I'd finally try to see if I could sort it out. I mean, what's the point of having a credit card at a foreign bank if you can't make purchases with it in Canada?. I don't know what it means that short codes only work locally. Does it vary by carrier?
Been with PM for more than a year so that's not it.
Hi @trusted_source1
were you ever able to get the 2FA code from that overseas bank?  It could simply be the fact that their code might not come to Canada at all
Please check with you bank to see if there is alternate ways for 2FA, like email or Authenticator app.  Better to use the authenticator app but email would be ok if that is the only choice
trusted_source1
@trusted_source1
please note that international shortcode text, like 2FA text from US banks, are not guaranteed., it is a hit or miss. Regular international text are ok but not shortcodes.  It might work on some providers sometime and experience show it will broke sometime
only Canadian shortcode text found here are guaranteed
https://www.txt.ca/en/current-short-code-programs/
Also, if your just ported in your number, regular Canadian shortcode text might delay 3 to 7days.   Some banks  put the delay on purpose in case of sim fraud
HI @trusted_source1
have you ever receive those code on PM sim card before?
Foreign bank 2FA might not work as they sent via shortcode but shortcode only works locally
@trusted_source1  If you just joined PM and it’s been is the a week . It should start to come . Takes some time for the 2FA to know you truly change carrier
