VOICE MAIL IS NOT WORKING YET AGAIN
cndkustoms
I can not check my voice mail it will not accept my password now is going on i need to get this message very ipmortant and i can't even get to it this service is getting worse byu the day first there was a chat window to get help by talking to a person now that has vanished like
edited by computergeek541: inappropriate language removed as per terms of service
Timer
@cndkustoms
turn off device and turn back on and tried to call your number from same device.
How To Use  Voicemail Features (publicmobile.ca)
and check your  Voicemail Access Numbers - (publicmobile.ca)
@cndkustoms - this has happened before? What did you do to correct it then?
Restart your phone and do a reset of network settings. Then reset your voicemail contact.
Delete your voicemail contact in your phone and manually add a functional voicemail number, @dust2dust has provided one of them above.
You may check out others that may work and can choose one local to you, if you like:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
dust2dust
Call 1-778-580-4001. Listen. Then you can fix it after. It's likely the voicemail access number that needs to be changed.
