Upgrade from 4G to 5G
androidjim
Do I need a new Sim card?
9 REPLIES 9
NateDog1
hey @softech i tried doing the method sheldon pro suggested and it didnt work for me. Not sure what i did wrong but i followed all his steps and nothing happened.
Right. @mtbman - your assistance is requested 🙂
This user wrote a detailed instruction list to enable 5G on S20 phones. And also see this reply from a known expert of the forum:
https://productioncommunity.publicmobile.ca/t5/Get-Support/5G-network-not-regonized-not-registering/...
androidjim
Samsung S20 5G
@androidjim  Have you tried setting your phone network to 5G and note even with phone on LTE you will still get better speeds of 100mbs 4G plan being in the 5G plan
Do a speed test to confirm
Speed test
https://www.speedtest.net/apps
What's the make and model of the phone? This place is up to some shenanigans around some devices and 5G.
androidjim
Yes I bought a 5G plan but never seem to be connected to 5G. Maybe it's just the area I'm in but service says I should get 5G in this area
HI @androidjim
no, you don't.  You use the same sim card for 4G or 5G plans
@androidjim  No you don’t just change your plan to the one you want and change for next renewal so you don’t lose money in your current cycle . Or if it’s a new phone you have just swap sim out of old phone and put into new phone
