02-24-2022 01:18 PM
Went to make a call and was informed I was out of minutes... I have an unlimited plan so I am not sure what's up??
BT
02-24-2022 08:24 PM
@yestermornin wrote:Says i have no minutes and will not connect the call. : (
@yestermornin - if you have a Canada wide unlimited calling plan and you are getting that message, it is an unfortunate glitch.
So, you are not connecting even after added a 1.
Well, then you need a network refresh, I would think.
Refresh your network by:
I was getting that message for a period of a few weeks about a year ago (was on the $25 unlimited calling plan). Doing one or more of the above let my calls complete.
Then eventually, those message stopped.
Hopefully, the will stop for you too soon.
But, it if the message continues and you cannot connect, then it will be time to submit a ticket to the customer support agents (CSA), methods found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
02-24-2022 01:54 PM
@yestermornin : Click this and hover the mouse over the image and then click the little x in the upper right corner of the image.
02-24-2022 01:47 PM
HI @yestermornin delete your picture... too much personal info there..
So, you tried reboot your phone ? Reboot it and put a 1 in front of your 10 digits.
02-24-2022 01:45 PM - last edited on 02-24-2022 05:20 PM by computergeek541
02-24-2022 01:43 PM
I did not but I will try this.. Thanks!!
02-24-2022 01:42 PM
02-24-2022 01:25 PM
02-24-2022 01:20 PM
@yestermornin : Check the number as being the right number and also add a 1 in front. If not a Canadian number then do you have any non-Canadian add-ons?
02-24-2022 01:20 PM
Any current plan $25+ has unlimited Canada wide in/out calls.
Did you try to reboot your phone?
02-24-2022 01:20 PM - edited 02-24-2022 01:20 PM
@yestermornin What exactly did the message say? Is it possible that the message said something like "this is a long distance call blah blah"?. If that's the case it's a standard message just ignore it and let the call complete. To avoid that message put a 1 infront of the number.
Let us know.
