Unable to port phone number.
gargoyle844
I went to profile, and transfer the number: xxxxxxxxxx but it said : "Unable to port number."
If I still want to port the number: xxxxxxxxxxxxxxx,      what can I do...??
Thanks @computergeek541 , I came late
hi @gargoyle844 in that case, pretty sure the port was already requested and hence you got the error
@hTideGnow wrote:
Hi @gargoyle844 did you requested that once already??
And check if the phone number is eligible
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
There's no need to check using that tool as before I removed the phone number for the first post, I checked the origins of the phone number. It's originally assigned as a Telus Mobility/Koodo Mobile/Public Mobile phone number.
Yummy
Confirm if your number is eligible to be ported to PM using this link:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
As your number was originally a Telus (Mobility) number, it can definitely be ported to Public Mobile if it's not already at Public Mobile.  By any chance or you currently at Koodo on a prepaid account?  If that's the case, you would need to open a ticket using the chatbot.
If the ticketing system within the chatbot gives an error message, send a private message to CS_Agent.
