07-24-2019 04:02 PM - edited 01-05-2022 06:05 AM
Hello Team,
I have recently moved to Public mobile, few months back. I have registered new user during that time.
Even though I am trying with the correct user name and password I am unable to login my account. Can somene help with this. I have been trying from past 3-4 days. But no luck with this.
07-24-2019 04:49 PM
@duddusubbu wrote:Hello Team,
@duddusubbu Just a reminder the username to your selfserve account is your email not your community username. Are you using the email that you used to sign-up?
07-24-2019 04:04 PM
Did you try the forgot password option ?
https://selfserve.publicmobile.ca/forgot-password/
If you still have problems then contact a moderator.
Moderator can be reached at
