USA roaming only partly working
NealS
Hi,
I have a USA Roaming Data Talk and Text 15 day package. It is enabled in my account. The data roaming is working fine. However, I am unable to call or text on the roaming package. My status says I have "-1 messages left" of unlimited Txt and "-0.02 minutes left" of unlimited talk. I am into 7 of 15 days. I have restarted my phone. My carrier here in the USA says AT&T. My samsung phone is LTE/WCDMA/GSM enabled.
Any ideas on how to get my talk and text working would be greatly appreciated.
NealS
Setting to 2G on the AT&T network does not work. No T-mobile available in my area.
After trying that did you restart the phone? Should work with T-Mobile then but you said none in your area.
I have seen some people with success right away and some people unfortunately still cannot connect.
Sorry that it's not working for you.
NealS
Phone is on LTE and connected to AT&T. Tried 2G mode and connect to AT&T. No T-Mobile network in the area that I am in. Still not working.
Sansan
You can try
If possible, put your phone to 4G/LTE and connect to T-Mobile or AT&T.
If calls still don't work, put your phone to 2G and connect to T-Mobile. From the settings menu.
I hope this will be helpful.
