USA data talk text package not working
jobella
Bought your 20$ USA roaming package yesterday. Landed in New York this morning and had no data! Wrote to moderator asap. Got on my connecting flight and landed in New Orleans 4 hours later. No response from them, issue still présent and couldn't book my uber because no internet!!! I have now lost a whole day out of 10 day purchased! I was able to call home so not sure what the problem is but I hope it is resolved asap as I am currently stuck in hotel lobby in order to use their internet.
Thanks
J
srlawren
@jobella I see you selected my reponse as the solution--does this mean you were able to activate your roaming data?  I hope so.  Enjoy your trip!
srlawren
@mimmo wrote:
@jobella make sure roaming Is is enabled as well as data being on.
https://www.gadgetdaily.xyz/quick-tip-how-to-turn-off-data-roaming-on-android/
@jobella in OxygenOS, go to settings, SIM & Network, SIM1 (or SIM2 if that's where your PM SIM is), then check your Roaming setting.  It needs to be on:
mimmo
@jobella have not heard back, are you still having  issues?
mimmo
jobella
Hi,
Mobile data on.
Keep getting exclamation that I have no data because I left my region.
I am using a OnePlus3
mimmo
@jobella@If you can call that means it should be working. Can you receive calls? Or sms
Is data roaming on?
What phone are you using?
