03-18-2024 10:39 AM
I have a 50.00 is talk text pkg and want to add US roaming. What’s the difference between 250MB and 1 GB and 3 GB?
03-18-2024 04:52 PM
Please post a screenshot of your subscription details, minus any personal information. If you actually have a Canada/US plan you do not need a separate roaming add-on.
Also if your plan is $50, there are cheaper options for Canada/US starting at $39 now. Might want to check it out.
03-18-2024 11:12 AM
hi@Tom57
you shouldn't needt o add a roaming addon to have it work. With the Cana-US plan, all you need to do is to enable Mobile roaming data on the phone.
I think you should check with support agent and ask them to fix it and refund you the addon that you shouldn't need to buy, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
03-18-2024 11:01 AM
I do have the 50.00 a month Canada US plan but my data didn’t work until I added the roaming add on.
03-18-2024 10:59 AM
I'm confused also...do you have one of the US / Canada plans as your regular plan ? If so, that comes with data that can be used in either country. You also shouldn't need to buy a data add-on unless you've used up all your regular plan data.
03-18-2024 10:54 AM
My data wasn’t working when we first got down here until I added the US roaming add on. Confusing.
03-18-2024 10:52 AM
@Tom57 wrote:I get that. Last month it was 15.00 but this new billing offers 10 20 and 25 dollars. I don’t use that much data so the 10 dollar will likely do. As I already have the monthly plan Canada US talk text, I’m guessing I no longer need the 15 dollar add on
If you have the US / Canada plans...you won't need the data add-on unless you run outta the plan data.
03-18-2024 10:52 AM
Thanks
03-18-2024 10:50 AM
@Tom57 If your plan is Canada/US you don't need any add-on unless you're likely to run over your plan data.
03-18-2024 10:49 AM
Thanks
03-18-2024 10:47 AM
03-18-2024 10:42 AM
03-18-2024 10:41 AM
HI @Tom57
they are all 15 days long data add-on. the amount of data is the difference. If you think you need to use a lot, get the 1GB or 3GB
and if you need text and voice when you are in US , get the bundle
03-18-2024 10:40 AM
@Tom57 Price and amount of data
