4 weeks ago
Bought package before leaving. Worked the first day and stopped on the second morning. Online used 1.3GB.
Tried to restart the phone nothing works
3 weeks ago
self solution removed
4 weeks ago
Worked thx
4 weeks ago
@Jeandesnoyers - Hmmm. It may be an issue with your phone.
Please manually select T-Mobile or AT&T as your provider.
Also make sure that Data Roaming is enabled.
Also try to set phone to 4G / LTE.
As a last resort try to reset network settings ** You will lose all saved bluetooth and wi-fi connections saved on your device, although you can easily add them back to your device afterwards **
If nothing works, contact CS_Agent here:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article! ⚠️
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
