a week ago
a week ago
In the US you need to check some settings on your phone:
1) Turn Data Roaming ON
2) Set Preferred Network to 4G/LTE (5G AT&T doesn't work)
3) Verify that you're connected to either T-Mobile or AT&T. If not, manually connect to one.
If you were connected to AT&T 5G, or didn't have data roaming on, or somehow connected to Verizon, your service would not work. Also for phone calls to work you need a VoLTE device per Public Mobile's whitelist:
https://www.publicmobile.ca/en/on/get-help/articles/volte
Having said all that, because it didn't work you can log a ticket via the chat bot and see if they'll consider refunding you.
a week ago
I would contact CS and tell them it did not work for you.
Private message CS Agent at: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
a week ago
@IrenaB - You can get a credit here by CS_Agent:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
