03-25-2024 11:12 PM
WIll the $15 US Talk and Text add-on still work (with VoLTE over 4G/LTE) with no US Data add-on? Does it require Mobile Data to still be enabled on the phone, even though there is 0 Gb data available ? Does the Data Roaming setting on the phone need to be enabled as well, even with no US Data?
03-25-2024 11:25 PM
@dc2024 wrote:WIll the $15 US Talk and Text add-on still work (with VoLTE over 4G/LTE) with no US Data add-on?
Yes, absolutely.
There is no need to buy data if you don't need it. Most stores and locations there will have free WiFi.
Hey @dc2024 Read above! 🙂
Side note, when you DO get to the US, just go into your network settings, turn off automatic and choose T-Mobile then reboot. You should be up and running.
03-25-2024 11:20 PM
You don't have to have data, that's a separate add-on. It will work without the data. With the $15 talk and text, no data is required but roaming needs to be on. You can connect to T-Mobile or AT&T depending on your location.
Connect manually, remove auto connect.
Yes, put your phone to 4G/LTE and connect to T-Mobile or AT&T.
If calls still don't work, put your phone to 2G and connect to T-Mobile.
