US Roaming with friends
dkhopkins
If my friend and I (both from Canada) get a US Roaming Add-On and then travel to the USA, can we text each other?  Does the US Roaming work in Hawaii?
Thanks
Spudster
@dkhopkins
If you both own iPhones, you can iMessage each other while in Wi-Fi zones or with a data-only plan.
JL9
If you both have a PM plan then you can both get the add on and that should work. As for Hawaii, I have heard differing experiences with PM customers. The 3G issue doesn't seem to be helping, a more reliable and potentially cost effective solution may be to get a prepaid local option in Hawaii and/or voip app.
hairbag1
You sure can..you can call and text eash other for 240 hours while in US. Seems to work fine in Hawaii too.
Yummy
Unlimited U.S. Text Only = $8
Yes, you will be able to SMS each other.
Hawaii are part of USA so it should work.
