12-14-2023 09:17 PM - last edited on 12-14-2023 09:22 PM by computergeek541
I purchased the add-on before my trip. When I went across the boarder I was notified that I had entered the US and that roaming was on. I can text and phone, but I have zero data. There's no minutes being recorded on my add-on, so now I don't believe that it is working at all and I'm unsure what I'm getting charged for.
I have turned my phone on and off, turned my roaming on and off, turned the network to manual and back to automatic. And turned the VoLTE on and off. Nothing seems to change it.
I can't submit a ticket, for some reason. I can not understand.
Any suggestions????
12-14-2023 10:47 PM
I have done the LTE thing and the T-Mobile/AT&T thing and nothing.
I will try the messaging.
12-14-2023 10:46 PM
Ya, see, I had done that 3 times already today... Any other suggestions?
12-14-2023 09:34 PM - edited 12-14-2023 09:35 PM
Login to your account and check if the US Roaming data bundle is in the Subscription & Add-on section.
If it is reboot your phone by powering off then back on.
12-14-2023 09:19 PM - edited 12-14-2023 09:24 PM
@Beckums42M Set the phone to LTE and make sure your connected to T mobile or AT&T
but you can submit ticket with this link @Beckums42M
send a private message To CS_Agents
