US Roaming Add-Ons
NarinderS16
@CS_Agent, what are my US Roaming Add-Ons options?
7 REPLIES 7
@NarinderS16
do you plan on being in US for longer than 15 days and using your PM add-on ? If so, there's some hints to minimize your aggravation.  If you buy the talk/text and data package and you run outta data before the 15 days...don't re-buy the whole new talk/text/data add-on...instead just buy the data portion of the add-on.
Unlimited talk and text to US and Canada. The data speed will be the same as it would be in Canada. It starts when you buy it. Leave the networks on automatic as it will connect to T-Mobile. Leave the modes on LTE etc. If your phone has not yet been enabled for volte then your phone needs to be able to switch down to 2G GSM for talk. Or you'll need to manually switch it.
Adding - and you'll have nothing in Alaska. Coverage is dependent on T-Mobile internal coverage. So you may find areas without coverage. Same as any provider.
@Glemlins Talk Text would be unlimited
The data speed is according to your plan.  But I think some people said with 5G plan, they still get 4G speed.  But even wtih 4G speed, it is around 100Mpbs, which would be more than enough for most situations.
Glemlins
That's what's listed but no actual details as to what they fully entail..  Is it unlimited talk/text and is there a speed limit to the data?
@NarinderS16
these are the US roaming add-on options, they are all 15 days and the countdown start from the moment the add-on purchased successfully. So, only buy when you are ready to use or shortly before your tirp
Bundle - US Roaming - Talk, Text and 3GB Data (15 days)- $30 (25 Reward points)
Bundle - US Roaming - Talk and Text (15 days) - $15 (10 Reward points)
Data - US Roaming - 250 MB Data (15 days) - $10.00 (5 Reward points)
Data - US Roaming - 1GB Data (15 days) - $20.00 (15 Reward points)
Data - US Roaming - 3GB Data (15 days) - $25.00 (20 Reward points)
dust2dust
Talk/text
Talk/text/3gb data.
3gb data
1 gb data
.25 gb data
Click on plans up top and scroll down to open out the add-ons list. Or shop add-ons in your account.
@NarinderS16  Talk text and data 15 days cycles start soon as purchased
