08-25-2022 07:43 AM - edited 08-25-2022 08:14 AM
Good Morning, I have a question, My son and I have accounts with Public mobile and my son went to change his phone plan and noticed that it under my cell phone, the two telephone numbers are somehow linked to one email address . Is there someway this can be resolved.
thank You
08-25-2022 07:51 AM
@cmurphy Please do not post your account number for your own protection, this is an open forum. Please go back to your post, click the down arrow and then select Edit Message
PM system is one account , one email, so there is no way they are both using the same email. However, maybe you used the email Alias as a workaround?
I am not sure if Support can help in this case, usually once change is made, it is made. You can certainly change it back to the old plan for next cycle. I am afraid Support might not be able to just swap the plan for the lines. But of course, you can try
to open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
08-25-2022 07:49 AM
@cmurphy Remove your account numbers you are on a public forum anyone can see your personal info,to do that go to top right corner of your post click on the down arrow in the circle to edit your post
08-25-2022 07:46 AM
@cmurphy hi only a cs agent can fix that
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
