Trouble porting Number
AllanL
  • Hi i got a message
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
but then no one called me and my number didnt port, i need help
Shaun26
Please send me the number too?
AllanL
Thank you @hTideGnow it worked out, thanks for your input 🙂
Hi @AllanL
give them the account # of the old carrier
quickest way to get this resolved is to call the porting support team, I will send you the number , check your community inbox for my message
